Reman
- Bristol, UK.
Hi everyone, You've all been so warm and welcoming since I joined yesterday that you've only got yourselves to blame for me asking stupid questions now. LOL !
Anyway, I just want to check I'm not being thick here.
I understand that the point of adding a 24V PSU to cheap MIG welders is because the voltage on the transformer's wire feed tap drops off and becomes unstable when the welders striking an arc.
But does the wire feed board on my SIP Migmate 100 see any power until the welders trigger is pulled and the transformer energises? After looking at the circuit diagrams I've found for other SIP machines of the era it looks like there's no actual "trigger" signal to start the feed. All the feed control board does is sit there waiting to be powered up so it can start spooling out wire at it's pre selected speed?
OK, If that's right, Doesn't that mean I could just cut the 24v connections to the wire speed board, use those to energise a 24V "Truck" relay, run the positive side of a 24V (2 or 3A) laptop style power brick through the relays switch, and run the PSU's negative directly to the original negative on the wire feed board? Unless I'm missing something this would mean a constantly powered PSU having it's output "Connected" (And subsequently having the wire feed running) only when the transformer is energised, and the bare minimum of intrusive rewiring of the welder? I know doing it this way wouldn't bridge the feed motors terminals and stop it dead, But just to get a more stable wire feed speed, Would it work?
I'm only asking because I HATE playing with high amperage equipment. Whenever I have to do this sort of stuff it literally make's me feel like I'm going to vomit ! So I'm thinking that if I can just pre assemble a stupidly simple collection of 2 bit's, Then just crimp/solder 4 wire's when the covers are off the welder I'd feel a lot better about doing this mod.
........ Or am I missing something?
Reman,
Reman,
