J johnsom New Member Messages 4 Location kent Jul 29, 2014 #1 please can someone help I have the above mig which works great but now the trigger is pulled the wire does not stop feeding when trigger is released ???????
BrokenBiker Member Messages 11,576 Location Newport, South Wales Jul 29, 2014 #2 does it stop if you turn machine off and on again? or does it keep feeding as soon as you turn the unit on again?
J johnsom New Member Messages 4 Location kent Jul 29, 2014 #3 brokenbiker said: does it stop if you turn machine off and on again? or does it keep feeding as soon as you turn the unit on again? Click to expand... if I turn it off it stops feeding but ok again when turned on until u pull trigger again
BrokenBiker Member Messages 11,576 Location Newport, South Wales Jul 29, 2014 #4 could be a sticky relay, or a problem on the pcb
M Montreal New Member Messages 25 Location uk Jul 30, 2014 #6 Sounds simple. Could just be the flat metal contact in the torch touching' in the on position. Take torch apart and see.
