scooterist007
New Member
Hi there, I was given a sip t177 ac/DC inverter Tig welder from work, it doesn't work so they decided to buy a new esab instead of repairing it, so lucky me (maybe) I get to take the old one home!
Ok this is the problem, when you arc up, there is a spark in the spark gap and then a light comes on the front panel, The light says oh, I've looked in the manual and it doesn't say what it means. Anyone got any ideas what it could be? Also if the spark gap is too wide, would this cause this problem? Also does anyone know what the spark gap should be? I thought it should be around 1mm, however the gap is a lot wider than 1mm. Thanks in advance.
