Hi all first post coming up.
I was given a SIP ideal 180 a couple of months ago and I have been practising my welding ever since. I have been picking up hints and tips from friends and from off the message boards on here (many thanks!). I have even rewired my garage onto a separate power feed for the 32A blue plugs.
A few weeks ago, a friend said that I was not getting the penetration from the welder that he would be expecting. So i ran some of the tests performed on this forum, i.e. butt weld two bits of 3mm plate together and bash the 'life' out of them. All went well and I split the steel, but in the end the weld did lift and looking at the other side of the weld, there wasn't as much penetration as I would have expected.
Reading other posts my questions are:
1. From a SIP ideal 180, would other users expect to have good penetration from this welder, especially on the test performed
2. The welder is ~ 10years old, should i consider a new welder or refurb it?
3. The project that I have in mind I will be regularly welding 2, 2.5, 3 & 5 mm steel box sections and 5mm flat bar - Is this welder suitable?
I am also using 0.6mm wire and CO2
Many thanks in advance for any comments.
