SirDick Diodenob esquire
I have watched the forum tutorials and a few dozen youtubes making plug mig welding look easy. I am just about ok with arc for thick jobs and good with oxy acetylene car welding and am thinking about giving up on mig and getting my old BOC portapak out and renting the bottles, it seems so much easier than mig but I will persavere a bit longer as even the small oxy and acetyline bottle rentals are now a rip off. I have sprayed the practice pieces with proweldc which I think is a weld through copper based primer. The sill needing replaced is 71cm long and the good bits that are not rotten on the inner sill were originally spot welds so I am hoping that plug welds will be ok for the mot ? The whole length of the outer sill is normally covered with a plastic cover. I have checked the earth connections which are low resistance , setting 2 for the wire speed, worked up to setting 3 for voltage and still no good apart from seeming too high , done about 20 tests none of them penetrating the proweldc, does this stuff work or is it a waste of money, should I clean it off around the weld area, I see some comments by youtubers advising not to weld through it but I was under the impression that is the point of weld through primer.
Edit ; Just measured the drill bit properly, my plug holes are 8mm and not 6mm.
