Dissconnected
New Member
Ok so the machine was working fine then the next morning was completely dead so we put it away to settle down/dry out for a couple of days thinking hopefully it was just damp or something... then we plugged it back in, this time you can hear the fan fire up but when you press the trigger on the torch there is nothing... there is a box inside that normally clicks when you press the trigger which seems to be doing nothing even when pressed in manually it will just get a spark but still no gas or wire or anything? the pcb looks intact if a little dirty, and also there was a red led next to the fuse on the front which isnt on anymore... We have had the machine for just over a year with no problems till now, it gets alot of heavy usage on high power in cold/ damp conditions... Any ideas what could be wrong? would it be possible to fix ourselves? Any help/ suggestions would be MUCH appreciated. Thanks in advence! Ted..
