sparkymike
Hi,
I have a chance to buy an SIP25 plasma and have been given the machine to try it out. However all was not plain sailing and first there was a dodgy gun switch and then the air regulator was leaking like a sieve and now all seems to be working except the power seems to die as soon as I touch the metal and all I get is a small spark and that is that. The torch is a Binzel PBS 21 and I believe it is a model KZS version. I have now found that the spring support sleeve behind the nozzle is missing from the torch. Would this cause the cutter to not operate?
Air pressure now is ok and the led's on the front panel tell me that the pressure is correct and in range.
One other point,
On the diode bank there is a round flat disc type of capacitor across the terminals. What is this for?
Mike.
One other point,
Mike.
