Hi, I know there are topics on modifying the wire feed, I'd just like a little help diagnosing the problem/testing stuff and then a parts supplier.
From cold the wire will feed normally for about 1.5m and then stops and starts.
I've stripped and cleaned the gearbox and nothing obviously wrong so stuck a voltmeter on the motor.
Voltage at first is around 14v but when the wire feed hesitates increases to around 16v, then back to 14v.
Impossible to do more than a spot weld before the problem starts so need to fix it. I'm Ok at soldering so can replace parts etc but I don't have a clue which ones.
Can anyone advise please.
Cheers
Wookster
Cheers
Wookster
