JimM
I'm planning on buying a 3 phase milling machine and am looking at my options regarding the electrics.
The machine has 4 motors so an inverter is no good, static converter will leave me down on power so I'll be going the rotary converter route. Plenty of info on the net about building the unit but my first issue is uping the 240v to 415v (ish) as the mill motors are not dual voltage.
I have been given an old static converter which I'm hoping will come to the rescue. Ideally I'd just like to use the transformer part of it so that I input 240v single phase and output 415v single phase. Here's a schematic of the converter
http://www.mediafire.com/?sharekey=7e0b64b434e472ded956df2962098fcbe04e75f6e8ebb871
The incoming 240v connects to AC1 & AC2, and I'm thinking that if I simply leave out the wiring that runs to the external condensor (ie box of capacitors) then I should get 415v at R & B. Anyone who knows more about electrics able to confirm this ??
Many Thanks
Jim
If I simply leave out the condensor wiring (ie capacitors)
Many Thanks
Jim
t
