Hi
I'm using the disposable bottles at the minute and looking to change to the larger bottles so will need a regulator.
I've been told that a two stage regulator is much better then an single stage regulator as it's much easier to get a constant flow of gas (which will also avoid wasting gas).
However, the majority of gauges look to be single stage and the two stage ones I've seen are very expensive.
If I used a single stage gauge but with a flow meter attached, would this achieve the same result (ie more constange flow rate) as just using a two stage regulator?
Maybe this regulator and this flow meter?
Cheers
James
Cheers
James
