sako243
- My mansion in Wales
Normally these kinds of devices use SPS to represent digital bandwidth and Hz to represent analogue bandwidth.
If you're looking at purely digital signals or perfect sine waves then you can get away with being close to Nyquist (half the bandwidth) to fully represent the signal. If it's a more complex signal then ideally you want a greater oversampling ratio.
So any signal will be limited by the front end, there's no way you can get around that without changing the front end. Having a higher sample rate than the front end bandwidth allows for extra signal processing techniques to be applied that can be used to improve the fidelity of the displayed waveform.
Make sense?
Make sense?
