Gareth J
- North Cornwall
We all know that many people bough diesel cars for inappropriately short journeys and the associated issues with them.
After recently needing to use my car differently (more short trips, less long ones) but not wanting to change, I decided to try to mitigate some of the negatives from the short trips by installing an engine preheater.
I looked at several types, the sump pan heaters are probably better at reducing engine wear and diesel webasto types faster and better without electricity, but I chose a 3kW electric pumped water heater. I wanted to to prioritise getting the combustion chamber up to temp and do so fairly swiftly. It cuts in and out thermostatically.
Some hose, and a helpful blanked off port in the block (probably for Scandinavian models fitted with diesel heaters) and some time and it fits and works ok.
Takes the water temp from ~10C to 55C in about 10-15mins. Car starts and drives much nicer off the bat and gets up to temp in a few miles, lots less than without.
It's fitted with a remote blipper that I put together to make it come on for ~30mins. The same could be done but more easily with a "smartplug" but I was out of WiFi range. I tuck the cable away inside the drivers coin flap when not parked. The cable does have to hang out of the ajar door, which is fine for me (garaged and car not normally locked) but it could be tucked away outside too. Needs a minimum 16A connector and definitely needs to auto time out.
It's not a perfect solution but a workaround that cost a lot less than a different car and still lets me have the motorway cruiser. And makes the heating work quicker and returns better MPG.
Yes, the electric costs, but not so much as the diesel (maybe!)
