DennisCA
- Finland
This summer when my milling machine project is hopefully completed I want to completely remake my shop and assign more space to metalworking than how I got it now. The metal working area is currently the small area to the bottom right (1st picture), It will not be enough for the vision I have got of my shop. I will want to put in a small surface planer some day and a workbench that I can house a 630x400mm surface plate on.
I will separate the shop int two separate areas, either with a sliding door that goes into the wall, or with heavy plastic drapes.
Models don't look like what I really got for most part, but I've measured all my stuff so they are pretty dimensionally accurate with regards to the footprint they take up. Do you guys have any input on this? Like I am wondering if it's good idea to put all my machines against the walls, would the milling machine perhaps be better in the center of the room (assuming it would fit there).
Here, moved it to the middle of the room:
Since it is a Deckel it is operated from the side rather than in front, so I think it could work as well against the wall as long as the sliding head have clearance. In this configuration the welding table near the big door might be a bit cramped, but all these small benches are mobile and can be moved around the shop as is needed.
