Does everyone have a separate tank/gas mix for all their different metals that they weld? Say one for steel, one for SS, and one tank for aluminum? Is there a mix that you can use that works good on both mild steel and stainless? I wish I could get a tank of 100% of each gas and there was a special regulator in which you can change mixing ratios and switch gases.. Such a thing exist? Can you use brazing wire on aluminum? I want to weld aluminum sheet but not planning on getting a
Spool gun right off of the bat.. I will be purchasing the hobart 210mvp next week. Still have a lot of learning and reading to do. Planning on getting C25 and learning to weld on mild steel.
