Hi folks. Just wondering how people cut material from sheet or plate and then make the cut edges perfectly straight again. I have a guillotine but it only does 16 gauge. Most other stuff is cut with the plasma, but it usually requires a bit of post-plasma fettling, and then I find it very hard to get a ruler-straight edge on it - usually comes out slightly 'undulating' due to uneven grinding, or the odd 'nick' from the plasma cannon.
This weeks off-the-wall tool idea was to make a kind of vertical mill / spindle router thingy which would have an adjustable stop like a table saw and a milling cutter in a fixed position. You could 'feed' the plate past the cutter with the stop set at the correct width in order to get a perfectly straight edge on it.
Any thoughts??? Would be very simple to make.
Cheers, Al.
Cheers, Al.
