| Component | Recommendation |
| Bolt Grade | Use ISO Class 8.8 high-tensile steel bolts. |
| Hole Size | Drill 6.5mm holes. Too much "slop" in the hole will cause the bench to wobble. |
| Washers | Use large flat washers (fender washers) on both sides to spread the load across the 4mm steel surface. |
| Locking | Use Nyloc nuts or spring washers. Workbenches vibrate (hammering, sawing), which can vibrate standard nuts loose over time. |
In short:
Direct from google if you use AI modeWhich AI did you use to write that for you?
Could have been written by our quality department who also appear to have no concept of using the correct unitsWhich AI did you use to write that for you?
Gemini, because whats the point in asking a question he'll get loads of replies with opinions when he could have just googled it.Which AI did you use to write that for you?
Because AI often makes mistakes. So my dumb ass thought I'd get the opinion of professional metal fabricators.Gemini, because whats the point in asking a question he'll get loads of replies with opinions when he could have just googled it.
This. The cost difference is absolutely nothing.why use m6 when you can use m8 at the same price , the biggest load will probably be from dragging the bench about the floor , and the legs become a lever ,,
hard to get it in the boot of a mini if its welded ,,,,An even better time to learn some welding .. .![]()
thats why they make convertibleshard to get it in the boot of a mini if its welded ,,,,
Getting it in is easy enough, getting it back out again...hard to get it in the boot of a mini if its welded ,,,,
What’s the point in a forum then. What a low point this isGemini, because whats the point in asking a question he'll get loads of replies with opinions when he could have just googled it.
So your issue is basically that the first response was accurate for the yes/no scenario with a quick question to AI, instead of 18 replies of waffle? And as a result, this negates any positives of a forum?What’s the point in a forum then. What a low point this is
