hotponyshoes
- Somerset. Uk
Does anybody have experience with the ETFE type solar panels?
Basically I have two 12v batteries on a boat, I want to keep the charge topped up when not in use. They will both be isolated but one of them may be running a bilge pump occasionally.
I am pretty restricted on mounting space for the solar panel(s) as the boat has a sliding sunroof.
If I use the thin flexible type panels I can mount them on the roof behind the sunroof and when it opens it will slide over the top of them.
Obviously I wont get any power from them when the sunroof is open but I really only want them so the batteries are fully charged at the start.
The issue is I can not find completely flat solar panels. They all have a moulded outlet for the cable exits.
So, if I fit 2x 50w panels they are large enough for the outlet blocks to be out of the way when the roof is open.
But to do this about 1/4 of each panel will be shaded/under a radar arch.
I believe the etfe type cope with shading better than the traditional type but I dont have any experience with this?
Power wise, I am sure one 50w panel would be plenty to keep both batteries topped up even if the shade cost 50% of the output.
I am thinking of 2 because then I could wire them in series so should still get plenty of voltage if the shade lowers it on each panel.
I am not sure if the 12/24v charge controllers will cope with that though as the ones I have looked at so far look like they might base the output charging voltage on the input voltage which might be a problem?
