ElderWelder
I have a very old (50 years ?) max arc single phase which I have used for heavy welding on domestic mains. I noticed a slight damp patch on the garage floor on rolling the welder out. Suspecting a leak I carefully wiped the bottom of the tank but only found an area that was a bit rough. Further investigation with it up on bricks indicated erosion (internal). To cut a long story short the tank had 10mm of metal "concrete" in the bottom and this was bridging three holes in the tank the biggest being about 12mm dia.
This welder holds about seven or eight gallons of oil, I had a real fun time draining it through the largest hole into containers and into two five gallon drums and cleaning up, I lost about two pints, what a mess.
There is no drain hole but what I should have done was jacked a sealing pad up under the suspect area, DON'T DISTURB THE "CONCRETE" INSIDE , and then removed the top complete with internals and then got help to tip the oil into containers. The top (more than one person should lift !) with internals should not be put down but can hang from supports under the top cover. By luck had a steel frame handy. You won't know if you have this problem without opening and removing oil.
I am currently preparing for a new bottom (excellent machine) to be welded on taking away 10mm of the side, large areas of the bottom are down to one mm and less. Photos and solution later if of interest. Note this oil may come with a health warning.
