Hi,
I am new to this forum, I am trying to fix mu inverter welder. It is Selco welder, model genesis 145A with 2 modes: TIG and MMA. I've always been using it in MMA mode. It worked perfectly. Suddenly, it just started loosing power. When I start to weld, it makes the arc, melts the electrode, but very slowly, not able to penetrate metal, just drips some drops on the surface. Arc stays stable with no power. I've found the service manual, there are couple of diagnosis LEDs inside the welder which tell about the voltages - they are all OK. Checked potentiometer for regulating power, connections. No signs of burning anything but the little zener diode near to relay for soft start. I checked it, it is OK, just a little black from heating. I've found somewhere also that relay needs to be checked visually 5 seconds after turning on the master switch - so it works also fine. Before desoldering mosfets, diodes, capacitors and checking them, did anyone have a similar issue?
Thanks a lot for any help/opinion.
Regards.
Regards.
I'll try to do more research and diagnosis.
