whm_fab
Motorsport engineering
- in the shop
Hi Folks, just wondering has anyone used one of these with any success? they look like a good unit, but as with most things im also a bit sceptical. I need something reliable and portable for use out in the field when im not in the workshop, primarily for cutting exhaust tube, which it states is well up to the job.
My main concern and the ppivotal point in purchasing will be, given the design, it will be at 90 degrees to the pipe at all times so - would it cut a mandrel bent tube directly through the centre point of the CLR regardless of where it is around the bend? ie, will it cut a u bend tube without a cheated radius, and match up perfectly with a straight tube?
cheers for any input!
http://www.sealey.co.uk/PLPageBuilder.asp?id=20&method=mViewProduct&productid=13797
