So confused with sealey spot weld and stud weld nozzles, was not sure what make torch i had so emailed sealey to get advice on the nozzles for my welder which is the sealey mighty mig 150 they emailed back and said i can use the spot weld nozzle tb15 but there is no stud weld nozzle. so i purchased the spot weld nozzle and does not work for spot welding even had it flat out. but would be ideal for a plug weld as it left a nice circular weld well after seeing the weld i cant see why you cant have a stud weld nozzle.I then tried it on a friends machine not sure what make but his was 190 after a few attempts he managed a spot weld but with a lot of effort even he had it flat out.
but when you look at sealey website the info on the spot weld nozzle is identical to the stud weld nozzle. so i emailed sealey back to make sure they got it around the right way and they still say you can't stud weld with mig. but why are they advertise in the mig section stud weld nozzle.
is there anything else i could try to get this spot weld to work also i see somewhere else that these spot weld nozzles are for the mighty mig 250 upwards
