Hi Guys,
I am a beginner welder. I have been trying to weld up some brewing equipment with a flux cored 316 electrode onto 316 stainless steel with a SIP150 welding machine. My problem is I keep getting leaks.
Firstly is this easier with flux cored electrode, solid wire with shielding gas or tig?
Secondly if I am trying to weld around a pipe/internal hole, should I be trying to do 180 degrees, clean off weld and do remainder, or is there a technique to keep the weld pool at each end of the weld liquid to join weld ends up in one go ( ie. jumping from end to end)?
Thirdly is preheat likely to help increase penetration and joining to existing weld (have access to a butane torch)?
Fourthly, is this likely to be too difficult a problem for a beginner welder (keep getting cracks/discontinuities in the weld, can be seen when ground down, also note others in the forum are suggesting different alternative sealing methods - ie. silicone, brazing, soldering, paint)?
Cheers,
Jono
Cheers,
Jono
