the artfull-codger
- north yorkshire england
Knack the file?? not at all, that's what a die filing machine is for, I have a home made on I've used for 40 odd yrs for precision filing shapes,more of an accurate finishing tool, not to whack a 12" bastard file in for roughing out, I have a hegner & an american delta both parallel motion saws both cut metal when I use metal piercing saw [good quality] blades they cut through 3mm steel easily & thicker slower of course, I also use metal coping saw blades in them as well, but the best scroll/fret saw for metals is the meddings I have & I use lengths of bandsaw blades in this[cheap from autojumbles] & regularly use it for steel & alloys & brass etc but as the design is such that the blade holder upper is spring return as opposed to parallel motion it's not too good for thin fretsaw type blades, that's where the parallel motion saws do best.Using a tool for its designed purpose is one thing, but using a file when you have no control over pressure on the backstroke is just plain wrong. That's a quick way to knack a file.
Hope this info helps.
Die filer files and standard files aren't the same thing. Even now, I believe the standard procedure with files is pressure on the forward stroke only? I've always been taught that pressure on the back stroke dulls the file, and the same method is mentioned in any old tomes on the subject. Pressure on forward stroke, relieve pressure on the return stroke. Even back in school, heaving on a file both ways would have led to a crack on the knuckles. Work it may, correct it's not.
How do the standard files cope in a die filer setup, longevity wise? A die filer has been on my to-do list for ages, but it's just the lack of proper files for them which has made me never get round to sorting one. Always thought standard files probably wouldnt last five minutes, (a bit of exaggeration there, obviously
