BrokenBiker
- Newport, South Wales
Been asked if i can make a stainless or aluminium (probably stainless) mount for some solar lights to drop into...pretty simple design, bit of 30mm round bar with a 20mm hole drilled through the diameter at a slight forward angle, but they want it to screw into a fence post and have requested it be 1 piece, even after I explained it would be easier for the machining to make a plate to take a wood screw, then thread the mount onto the plate...or even recess the back of the mount and weld a wood screw to the back...
They are worried about the screw corroding for some reason...
So, are there any readily available form tools for the wood screw thread form? I'm limited to 8tpi so that limits me to the size of usable screw i can cut, in fact I doubt I will find a tool so much that I haven't even measured the pitch I would need to cut yet...
I could grind something, obviously, but they don't know that and if a tool isnt available, its an excuse not to do it...or atleast, do it my way
