Westerngeophysical772
3 years ago, I spent £500 on an exhaust for my Berlingo, Its an aluminised mild steel system .....3 years later its dropping to bits, I've removed the whole exhaust to investigate, and I have found that although the pipe work and cat and boxes are fine, all the welds show signs of severe corrosion and at 3 of the welds the aluminised pipe has perforated through where the weld joins the pipe. to me it looks like the system was aluminised in its seperate bits, then , welded together destroying the aluminised treatment and causing the corrosion at that point.. would you agree or disagree with that assessment?. cheers
