K kier Member Messages 278 Location Kent GB Nov 16, 2021 #1 I have 300 x 8mm by 100mm eye bolts gone rusty they were inside so only lightly rusted is Vaporust liquid on ebay any good or is there a better way
ronan Member Messages 11,399 Nov 16, 2021 #2 Citric acid solution, cheap as chips and easy and safe to use.
sardine Member Messages 3,723 Location Buckinghamshire Nov 16, 2021 #4 Works faster if you keep it hot/warm.
badabec Forum Supporter Messages 2,314 Location Essex UK Nov 16, 2021 #5 Wear gloves when you wash them after soaking. It's not going to burn you, just stinks.
ronan Member Messages 11,399 Nov 16, 2021 #6 badabec said: Wear gloves when you wash them after soaking. It's not going to burn you, just stinks. Click to expand... Yeah it can pong a bit can't it ?
M marlinspike Member Messages 2,081 Nov 17, 2021 #7 It will sting a bit if it gets in a cut. It def works better warm I've found. I top the tub up with boiling water every now and again and stir it a bit.
