OK. So I bought a Clarke 135TE a few months ago. I've been gradually learning to weld. I just had a quick question on how to add some rust resiatance patch repairs.
Say, for example, I'm patching a box section. Once I've completed the repair I'll apply the same brushed paint reatment to the face of the reapir as the rest of the chassis i.e. POR-15. But how to protect te inside face of the reapir within the box section?
I've been spraying Dynax S-50 cavity wax through the drainage holes in cavities that don't need repairing. The can comes with a 90cm flexible lance so that you get good coverage. Would this be sufficient to protect the metal from long term corrosion?
Other treatments I'd thought of:
1. Weld through primer - I'd need to use a metal fume mask I guess as welding inside.
2. Paint the inside of the repair with POR-15 paint - I guess it would catch fire or be compromised when I weld it?
3. Paint the inside with POR -15 high temperature paint (Black Velvet). I've been using it on my exhaust heat shields and can work up to 1200F. But I guess this too would fail/burn off at MIG welding temperatures?
Thanks for any ideas.
