Wendelspanswick
A pal of mine restores old cast iron solid fuel ranges, he asked me to TIG up some open topped water boilers that he'd fabbed from 1.6mm 304 stainless. These sit behind the cast iron facade alongside the firebox and provide hot water from a tap poking out through the front.
He's had one sat full of water before fitting and he's reported that the tank is streaking with rust on the inside seams, which is a pain as it's the only bit you see!
Trying to workout the source of the rust and the only culprit I can think of is that he used a 9" cutter to cut the sheet and the cutting disc had previously used for cutting mild steel.
Is this the likely culprit?
On my side of the job I used 2 strands of 1.2mm 316 stainless mig wire twisted together as filler (coz I have 15kg of it!) and no back purge as I am not geared up for it.
I wire brushed all the seams with a rotary stainless wire brush I use exclusively on my aluminium jobs.
