I am thinking of buying this to replace my 42mm evolution mag drill.. Has anyone got one of these and willing to share their thoughts on its pros and cons?
im upgrading as i feel i need more power for my twist drill bits and i need some speed control as drilling 22mm drill bit at 400 rpm is pretty bad as you can imagine so i need a drill with a wide range of speed control and could do with some tapping capacity.. can you power tap m20 bolts with this ? or should you still treat it as a hand tap?
I also want some clarity on the morse taper inserts as i want to buy some twist drill bits for it but not sure what size i need? and is the cutting fluid system delivery decent? the one on mine sucks and normally have to add it manually
