W.olly
- Radcliffe, Manchester
Hi again all. me at it again with these trailer hubs.
As I took for granted that Daxara trailer axles are as I researched are 1 inch they are not and are two different sizes.
I measured the axle and rear of the axle is 24.95mm and front is 19.95mm ( OD ) as the axle tapers down for some reason.
And both the bearings I have are 25.4mm ID and 45mm OD so no good
Now I have found that 30204 20x47x15.25 and 32005 25x47x15mm will fit but are 2 thou bigger on OD.
Should be fine ?
Question ?
Now after that i am wondering are the tapers on bearings the same. reason i need to know is that i will only be using the bearings and cage to set in the hubs.
Any help please
Should be fine ?
Question ?
Any help please
