M Mr shiney Member Messages 1,241 Oct 9, 2013 #1 I have been using my Oxy/Acetylene kit for brazing and cutting mostly and heating. I would like to have a go at gas welding with it. What do I need in the way of filler rods? Best source for them?
brightspark Member Messages 41,367 Location yarm stockton on tees Oct 9, 2013 #2 gas welding rods take your pick https://www.google.co.uk/#q=gas+welding+rods+suppliersor some motorfactors
M Mr shiney Member Messages 1,241 Oct 9, 2013 #3 OK, now the obvious questions.... What size for what thickness?
brightspark Member Messages 41,367 Location yarm stockton on tees Oct 9, 2013 #4 there only filler rods the blowpipe size dictates the thickness of metal to be welded. filler rods 1.6mm and 2,5mm
M Mr shiney Member Messages 1,241 Oct 9, 2013 #5 Ok thanks for that. I have a fill set of nozzles. So would 1.6mm be ok for having a play with say 3mm? It's more for fun than any practical use. I have MIG and TIG but have always fancied a go at gas welding and have the kit.
Paul. Moderator Messages 7,047 Location Northampton. UK Oct 9, 2013 #6 1.6 filler will be fine for 3mm plate, you can use mild steel tig rods for oxy acetylene welding,
brightspark Member Messages 41,367 Location yarm stockton on tees Oct 9, 2013 #7 http://www.google.co.uk/imgres?imgu...&sa=X&ei=UsRVUq34KeaJ0AXM2YBI&ved=0CDUQ9QEwAQtip size
M Mr shiney Member Messages 1,241 Oct 10, 2013 #8 Thanks guys, all very helpful. Now for a bit of practice.....
pedrobedro Man at Matalan Messages 13,150 Location CX near Chesterfield Oct 10, 2013 #9 Get some 2.4mm rods, the 1.6mm disappear too quickly when you are welding thicker metal. I use the thicker rods and a number 2 tip for everything now as they are easier to hold as well. (Also good for making hooks to hang painted parts on )
