Hi fellas , what are the chances of setting m10 rivnuts successfully with just a nut and bolt through 3 mm steel,
Cheers
Chris
Wind a nut onto the bolt, wind the bolt in then hold the bolt with a hex and do the nut up
Thanks fellas will order up some rivnuts now ,
Cheers
Make sure you get the ones with a countersink style edge so that you can set them flush with the surface and avoid a lip.
