fitting a reversing camera in a 12 plate DAF LF 7.5t...want to connect the trigger to the reverse light feed so it changes channel when you put it in reverse...any ideas where the best place in the cab would be to get a connection?
There’s a fuse for the reverse light that kills the reverse light if you pull it...was going to use a piggy back fuse connector on it but the power is always going through the fuse even when not in reverse...I think the switching is done by a relay...
