Hello everyone. I've been lurking on the forum for a couple of months and picked up some great advice so far. The tutorials are brilliant.
I did a welding course at college as part of my engineering degree 20 years ago and then restored a very rusty VW camper. Since then I haven't done any welding at all and even back then I was certainly no expert. I've got a new project that requires plenty of welding so dusted off the MIG, signed away my life to BOC for a new cylinder and treated myself to a Parweld auto-dimming helmet (as recommended on here and the best 45 quid I ever spent BTW). I've been practising on some 2mm thick sheet offcuts and, once I finally sorted out the wire feed on the welder, got back into it pretty quickly. But I've got one problem that I can't seem to solve so need your advice.
It's a 120Amp welder so I have the power on maximum and the wire speed near maximum (9 out of 10 on the dial) to get reasonable penetration. I get clean looking welds and smooth control except for the first one second or so. The wire speed is too high, stubbing aginst the work, and the weld is raised and the penetration doesn't look great. Then, after a second, it gets better and the weld is nice and flat. I'm assuming it's just taking a while to get enough heat into the metal. If I turn down the wire speed it's easier to start but then the wire starts to burn back. Is there a clever trick to it?
I'm using a very old SIP Autoplus 120, .6mm wire, Argoshield light at about 10l/min.
do you v the edges? and how goods your earth?
Actually I'm pretty happy with the strength and appearance of the practice welds so far but need to build up some confidence before starting the job properly. A bit more practice and fine tuning will probably do it. I've just been running welds on some flat sheet so far, I'll practice some lap and butt welds next and V the edges.
for my daughter but it needs extensive repairs to the home-made chassis. In fact it might be easier to start again from scratch. I've been more successful on thinner metal but when I stepped up to 2mm, that's when I struggled.
