Blakebn2011
New Member
Should i leave the welder on and earthed when i replace the MIG tip? I usually turn it off, i was just wondering.
hihi...sorry but it did make me giggle!
that really smells like fried bacon!
It does no harm to change tip with welder on, in fact if the wire is melted into the tip it helps to flick the trigger as you unscrew it to save trying to stretch the wire in the liner as tip comes out.
By leaving it earthed, I assume you mean leaving the weld work return clamp on the workpiece, not a problem.
If it's welded the wire into the tip It's easiest to cut the wire in the box then stretch the cable out before you try to remove the tip or you are putting twists into the wire in the liner.
never had a problem with twisted wire even in a 1 metre harness.I must be just unlucky then, I got a corkscrew in the swan neck on my old welder that's why I started cutting it.
Haven't got time to do that with production welders & robots!never had a problem with twisted wire even in a 1 metre harness.
i would lose too much time with that!
