Coo
Record 75 Vice
I've had an annoying grind/click when using my vice recently, so investigated it yesterday..
The spring has been trying to escape from the retaining washer, and had partially succeeded.
I had trouble trying to get near the split pin, but managed to pry the spring out...they're quite long!!
Question now, is where can I get a replacement Spring, Washer and Split pin?
I've had a good search, but not found one relating specifically to the 75.
But notice that kits were/are available....
Washer seems to be about 26mm inside and 35mm outside diameter...
Spring must be similar outside diameter, possibly was 100mm (4 inches) long...
Thanks!
Thanks!
