D dkw1972 Member Messages 45 Location North Yorkshire UK May 14, 2019 #1 I have acquired a Paramo No6 vice which needs a new pair of 6” jaws, can anyone suggest a supplier?
brightspark Member Messages 41,463 Location yarm stockton on tees May 14, 2019 #2 have you a fat wallet. you will need one either make your own or get a complete vice .there cheap enough at autojumbles
eLuSiVeMiTe Member Messages 16,282 Location ...... May 14, 2019 #3 Make em. Make a soft set while your at it.
D dkw1972 Member Messages 45 Location North Yorkshire UK May 14, 2019 #4 Can i just use bright mild steel or would it need hardening?
brightspark Member Messages 41,463 Location yarm stockton on tees May 14, 2019 #5 dkw1972 said: Can i just use bright mild steel or would it need hardening? Click to expand... would need to be carbon steel if you were hardening them bms would be ok if you didn't need them hard . depends what you are gripping
D dkw1972 Member Messages 45 Location North Yorkshire UK May 14, 2019 #6 Great thanks i’ll have a look through my tubs to see what i have., just realised i have some nylon perfect for making another pair!
D dkw1972 Member Messages 45 Location North Yorkshire UK May 14, 2019 #7 Do the jaw retaining screws tend to be similar across different vices? ( these have no slots left so are going to take some removing.
brightspark Member Messages 41,463 Location yarm stockton on tees May 14, 2019 #8 drill and tap fresh ones in
gordon stephenson Member Messages 7,430 Location Skelton in Cleveland U.K. May 15, 2019 #9 Vice jaws do not seem to be interchangeable, Particularly Record, You would think that their jaws could be turned top to bottom for a fresh top edge, but Oh no the screw holes are not on the centre line!! Makes sense to them, Sell more jaws!! Last edited: May 15, 2019
