Hi, how would you people go about repairing this?
Someone has already had a go at brazing it long before I got hold of it. If I mill in a square piece of steel and clamp it through the slide holes, the vice opening would be too restricted. I don't think there is the structural strength to mill out where the piece has torn from flat and bolt in a insert there.
Id like to braze it up again, but I have doubts I'd do a better job than the previous attempt, which would mean it would just break again. I also thought of machining some pins into the two pieces to give it a bit of mechanical strength and use the braze to back it up.
Now, will I get enough heat into this myself by preheating it in the oven for a few hours then using a oxy propane torch or is it off into the realms of someone elses kit. Alternatively I have the big tig, so would it possible to cast weld this sucessfully perhaps?
Its well into the hundreds of pounds territory to replace it with one this size, and the smaller temporary one just doesn't hold pieces quite as well as this one...
Your suggestions please...
