v8burbling
- UK
Hi all,
As title really. I have previously repaired an A-post with a repair panel and it rusted through fom inside out (not near the seam) within a couple of years. I had primed the inside and then painted with a waxoil underseal first. Probably a bad idea as I think the waxoil caught fire a bit inside when I was welding - not trying that again.
So now I'm doing main chassis rail repairs, what do you guys do to protect the inside face ?
Do you paint before hand with something like Bilt Hamer Electrox or an etch primer or do you leave bare and then use a cavity wax afterwards via a drilled hole somewhere and hope you cover it all ?
I guess even with the etch primer / electrox, the heat from welding blows the paint off anyhow does it?
Same question also for the inside faces of the box section that you have access to before you weld in the repair panel. They are quite heavily rusted. Still strong but it needs something sharpish to prevent/slow corrosion down. Been looking at Dinitrol stuff but that would again need spraying in afterwards to prevent fire risk.
Thanks, Matt
Thanks, Matt
