cardiffrob
- Wales, Llantwit Major.
Well, it wouldn't fit easily into any other forum...
My father has this old lamp from when he lived near Poole and managed to salvage one of the fancy street lamps that were being phased out. Massive cast iron body and a beautiful brass top to it. The years have taken their toll and now it has fallen to me to see if it can be rejuvenated.
There is a lot of copper sheet used in the design and it has many thick layers of paint, lots of rock-hard putty and encrusted bird poo to come off. So, first question is "should I try soda blasting copper and, if so, should I buy a huge 25kg bag of it"? Hard to know how much it needs. I have the compressor and gun plus a small Clarke blasting box but the grit and glass I have used before lasts for ever. Same with soda?
Next problem is the one of polishing the copper once the paint is off. Shouldn't be too hard to get a shine on most of it but I'm guessing that it has been soft soldered. Leave the solder showing or buff it away? Does the solder suffer from the salt air environment?
Once polished, what would be the best way to preserve the shine for a long time? Any brand name suggestions would be most welcomed.
Oh, and quite amazingly every single bolt and screw has come undone!
Thanks
Rob
Thanks
Rob
If the paint is really tough, even soda blasting may not shift it. I seem to recall a rtbcomp for one saying that certain finishes need some prep work even when more aggressive blasting materials are used, in some of the blasting related threads. I think he uses that that Methyl? something or other stuff. Brake fluid tends to be another thing that's decent at shifting most paints. Does need to be left on for a decent while to soften the paint up though, and might need several applications with scraping soft stuff off inbetween.
I couldn't remember what it was called for the life of me.
