I broke my Fourtrak due to body rot. Plan was to put another body, probably an Eagle firbeglass kit car item, on the rolling chassis however I found the chassis has also rotted on the top surface that isn't easy to inspect with body in situ. If you crossmember has rotted then I'd carefully check the main rails top surface as well
