I am modifying the hearth in out kitchen to accommodate the rayburn. At the base, the stone work is now exposed and needs covering and blending in with the current render. The walls are currently covered with a render I think- its cement based with a rough finish harder than plaster - its not plaster.
In the past I have had little luck trying to acheive an adhered finish with mortar mixes (generally 5:1 sand to cement that I happened to be using for block work etc).
What is the difference with renders applied to walls? I read that some have lime added but then toolstation seem to sell one that appears to just be sand and cement?!
What should I be doing to get a good finish that adheres to the stone wall and blends well rather than stands out like a sore thumb?
