Forward Look
Hi All,
I'm hoping somone here could help out?
I have a 1960 Plymouth Belvedere that has undergone a previous restoration. My concern is with the rear wings. These are large, flatish panels with most of the crown running top to bottom, but a little running lengthways, see image below:
About 20 years ago a lower-half patch panel was let into the wing, the seam being around 15" up from the bottom. The repair section runs from the tail lights to the rear door.
Although on the outside this looks pretty good,it has been 'shaped' with filler. The inside of the fender shows around three/four 'waves' in the panel. The peaks and troughs of the waves run top to bottom, the waves 'flowing' in a fore/aft direction. I guess from peak to trough is around 3/8" depth.
The wave crests/troughs are perpendicular to the seam.
I'm guessing the waves are there due to distortion caused by the welding but I can't say for sure. Both left and right sides are the same, with the same enormous patch panel.
I'd like to remove the filler at some point and dress out these waves, and try to metal finish the panel. I don't mind using a skim of filler here and there but would much prefer to do it all with the sheet.
Is it at all possible to try and remove these waves? The work was done a long time ago, long before I aquired the car.
And to add yet more difficulty to the situation, I am a novice with no access to oxy/acetylene gear. If shrinking was necessary I reckon I could stretch to a shrinking disk for the angle grinder (4" grinder).
Anybody got any ideas? Kind of don't know where to start with this one.
All the best,
Conor
P.S. - I assumed this was the best place to put this post, it has "panel beating" in the title. I'll move it if necessary though.
Cheers guys.
All the best,
Conor
Cheers guys.
