CRB
A nice day outside, so after adjusting the Octavias' gearchange to 'acceptable' I set to on the LT with a cutting disc.
Off with the rear light cluster lens, 1, 2, 3 screws out. then the ones holding the bulb unit to the body, 1, 2, 3, 4fxsake.
The last one will not budge and is corroded to the point of the cross being a shallow recess. I thought about cutting it between the body and the back of the bulb unit, but the screws are recessed below the perimeter. Drilling from the outside has not done much, and then I remembered they are probably hardened.
?Any good ideas gents?
I can get access to the inside but it is severely limited.
