finish off with grade 1200 wet and dry and polish up rubbing compound. it takes timeAny secrets to doing this...the sheets have got some minor scratches from handling.
Ive tried with some fine grit paper, removes the scratches but leaves a dull finish...maybe I just need finer paper?
Cheers
by its self then after the rubbing compound use solvol autosol or t cut to polishCheers....potentially obvious question......use the 1200 by itself or?
drill with a polishing mop on be faster then by handCool, will give it a go tomorrow. I take it the wet n dry needs to be by hand but the polishing could be on a drill/grinder?
