Forging company fined £750k after employee dies in machine accident
A FORGE from Halesowen has been fined £750,000 after an employee sustained fatal injuries when he became entangled in a 20-metre-long lathe.
It is sad that a life is lost but training is the key, it should be instilled Into you .An investigation by the Health and Safety Executive (HSE) found that Somers Forge Limited had failed to:
The third failure is telling
- Prohibit the use of handheld emery cloth on lathes
- Prevent access to dangerous moving parts of the lathe
- Ensure personal protective equipment (PPE) worn by workers did not create risk of being injured by, or drawn into, the lathe
- Undertake a suitable and sufficient risk assessment for the lathe, or establish a safe operating procedure
It is sad that a life is lost but training is the key, it should be installed Into you .
Common sense is dwindling I think in society, I was always taught, no loose clothes, hair tied back and the ultimate one
the machine will kill you given the chance.
Never used a lathe but have managed to get gloves caught in drills before. I can only imagine the damage a big or even small lathe can do hence why I'll never buy one.
It was the first one which caught my eye, how many people here do that? I know I do...An investigation by the Health and Safety Executive (HSE) found that Somers Forge Limited had failed to:
My thoughts too. But must confessI do use emery cloth sometimesEmery cloth on a 20m lathe?
i do it even though at college was told not toMy thoughts too. But must confessI do use emery cloth sometimes
i put some cloth on the bed though to stop grit knacking the bed
i did once get a bruised thumb as the emery wrapped round itI love some of their solutions for using emery cloth on the lathe. Like clamping a piece in the toolholder. That is then worn out in seconds. Then you have to stop and move it, then go again. No control of pressure or hitting certain areas. We was recommended a machine with an integrated brake and a Linisher type belt.My thoughts too. But must confessI do use emery cloth sometimes
then clip the chuck accidentallyI put the tape over a flat file….flat
its the chance you takeThat was my first thought.Emery cloth on a 20m lathe?
Emery tape is fine, normal, as long as its safe, ie make sure you only grab the tape by the end with the tips of your fingers ready to let go if it snags.That was my first thought.
