How do I figure this two dial regulator out?
One shoots up to 200ish when I turn the main bottle valve on, the second dial doesn't move until I open the valve on the bottom of the regulator, but it doesnt move much.
Does it only register properly when the button is pressed on the tig torch and the preflow begins?
If so how do you set it to 15cf (thingy-ma-jig?)
thanks!
thanks!
Have you got a 15cf (thingy-ma-jig?) regulator? Most UK ones will be in litres per minute. 10L/min is a starting point for MIG, but TIG is a bit less (TIG gas flow figures will have been posted here but I've not done the search). Definately set it while the trigger is pushed.
