Hudmut
- Derby
Just this week I picked up a pea shooter flow meter that goes on the end of my torch and now I really do not have a clue what flow rate I am using. All my meters give different readings I get there will be some differences between them but not at this lever.
If I open my bottle and set the regulator to say 15LP then set me machine to do a gas test and have my regulator mounted pea shooter wide open it will say 20LP if I now set that pea shooter to 15LP and test my torch with my new torch pea shooter I have a flow rate back up at 20LP ?
Am I and would you take my regulator mounted flow meter as law or the one that I can use to test my torch flow rate because right now I don't know what to believe should I remover some thing here and work from just one gauge /flow meter or should I be doing some things different to satisfy my want and need to know what my gas flow rate is because its a very important part of TIG welding as you all know and I don't have a clue right now what my gas rate I's.
