Hi, I have a problem with my regulator, when I weld everything is fine however when I stop for few minutes the right (flow) gauge keeps creeping up and up until around 40LPM then the valve on the bottom of regulator start to slowly release the gas. If I shut the bottle the pressure on the left (bottle pressure) gauge will slowly come down as the gas escapes through the bottom valve until 0Bar however the right (flow) will still be ad would stay at around 40 LPM until you release the trigger.
So my question is is that normal or the regulator is shot?
also its CO2 on argon mix bottle via adapter (regulator is rated at 300Bar and bottle has 200 - keygas)
this is exact model:
Many thanks.
Many thanks.
