BigBunny
New Member
- Cambridge, UK
Hello Folks,
I am new to MIG welding, so please forgive me if these are basic questions.
I have just brought a new welder (Clarke 135TE) and have just finished the bottle of CO2 gas that came with it. I calculated that it would be more cost effective to use a rent free gas bottle and opted for a Argon 93%, CO2 5%, O2 2% mix. I will be welding mild steel, 1.6mm box tubing.
I have fitted the regulator, please see attached photo, this includes a flowmeter on the regulator and a separate (more accurate or so I believe) flowmeter.
When I open the Regulator value in order to maintain a flow reading on the Flowmeter of 10 LPM (when the trigger of the MIG welder is pulled) indicated by the yellow tape. As you can see from my photograph I then have a reading on the Regulator Flowmeter of 20LPM. Would you expect to see this ? (I should say that at this point the valve on the tubular Flowmeter itself is open fully). But the ball floats at 10LPM.
I can hear the gas flowing out of the gun. It does sound a lot, lot louder than when I was using the small disposable bottle of CO2 gas.
Is this to be expected ? Or is the fact that I have, in effect, two flow meters causing me problems ?
The second photograph shows a practice weld. I am getting a brown deposit (soot for want of a better description) on my weld bead. This was not something I was getting with the disposable gas CO2 cylinder.
I have switched from using CO2 to using mixed gas. Is the brown deposit as a result of the new gas, or is my gas flow too low.
The bead also looks dull, with a little wire brush it still looks dull, again compared to a weld done with C02. Again, is the a characteristic of argon mix shielding gas ?
I am concerned that if I crank up the gas flow any higher I will cause turbulence and in effect pull in air into the weld, rather than having a laminar flow of shielding gas. And I will be wasting gas. I started today with 200bar on the cylinder.
Out of curiosity, what flow rate do you get from the small disposable gas bottles ? Mine just has a scale 1 – 6 on the regulator (Machine Mart, UK).
Thanks for your help and advice
Much appreciated.
Simon
Much appreciated.
Simon
